Paolo Bevilacqua Wed, 08/08/2007 - 01:58
  • Hall of Fame,
    Founding Member
Yes, you can. You user the special imager for this puropose that ends with _isv.
PRI and DSP are not used for IP-To-IP, unless you do transcodig, in which case you use the latter.
leungcm Thu, 08/09/2007 - 09:51
any doc regarding it? e.g. max connection, any limitation? .... etc
thanks
Best regards
