Cat6509 IOS 12.2SXF doesn't support IP SLA
Aug 7th, 2007
Hi Sir,
I have a Catalyst 6509-E with Supervisor Engine 32. Its IOS software is as follows:
Major Rel : 12.2SXF
Rel : 12.2(18)SXF6
Platform : CAT6000-SUP32/MSFC2A
Feat. Set : ENTERPRISE SERVICES SSH
Image filename : s3223-entservicesk9_wan-mz.122-18.SXF6.bin
From Feature Navigator, the feature "IP SLAs - ICMP Echo Operation" is supported. But in actual fact, the command is not available, as follows:
Cat6509#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Cat6509(config)#ip sl?
slb
Please advise.
Thank you.
B.Rgds,
Lim TS
limtohsoon Wed, 08/08/2007 - 00:30
I'd like to use IP SLAs ICMP Echo Operation to track an object and attach it to a static route, as follows:
ip sla monitor 1
type echo protocol ipIcmpEcho 150.50.1.1
ip sla monitor schedule 1 life forever start-time now
track 1 rtr 1 reachability
ip route 20.20.20.0 255.255.255.0 192.168.10.2 track 1
Since the command is not available on 12.2SXF, I guess the closest workaround is as follows:
rtr 1
rtr schedule 1 start-time now life forever
Cat6509(config)#track 1 ?
interface Select an interface to track
Unfortunately, I can't complete the configuration because the next command "track 1 rtr 1 reachability" is not available. Do you have further suggestion?
I just wonder why the output of Feature Navigator indicates that IP SLAs is supported in 12.2SXF but in actual fact is not. The tool seems to be wrong.
Thank you.
B.Rgds,
Lim TS
Ok..this is what I see under command looksup for "rtr responder". Looks like you need to upgrade to 12.2(31)SB2
Command History
Release Modification
12.0(3)T
This command was introduced.
12.3(14)T
This command was replaced by the ip sla monitor responder command.
12.2(33)SRA
This command was integrated into Cisco IOS Release 12.2(33)SRA.
12.2(31)SB2
wochanda Wed, 08/08/2007 - 07:19
If you want to run 7600 code on your 6500, you can upgrade to something in the 12.2(33)SRA train.
If you prefer to get an actual 6500 release that supports this, wait 1 month for 12.2(33)SXH to come out. It will support this feature.
