VPN issue
Aug 7th, 2007
Hey
I have a static vpn connection between to sites. Sometimes it seems that the connection goes down, just for som seconds, but it happens often.
I issued the command : sh crypto engine connections dropped-packet
an i got this output :
Packets dropped because of encapsulation/decapsulation failure:
Interface IP-Address Drop Count
FastEthernet0/0 x.x.x.x 1
Packets dropped because of abnormal event occurred:
FastEthernet0/0 x.x.x.x 7763
_______________________________
i checked the switch its connected to, and it doesent seem like the interface is flapping, ( i cant se any errors )
any suggestions how I proceed withe the troubleshooting ?
-TH
Paolo Bevilacqua Wed, 08/08/2007 - 02:04
  • Hall of Fame,
    Founding Member
use some kind of "internet continuity" test between the two sites, like a continuous ping, what'up, etc. If you see "holes" in times corresponding with the VPN problems, you know that is caused by packet loss in the internet.
