08-08-2007 12:04 AM - edited 03-05-2019 05:46 PM
Hello all,
I have the following :
Why does the Cisco 7960 phone NOT put a sticky mac address automatically under the switchport, just the PC does?
It seems to work, but am not sure why.
Also, I dont require "maximum macs" to be set to 3 do I? Like when you use Avaya?
Many thx indeed,
Ken
interface FastEthernet1/0/10
description IP Phone with desktop connected
switchport access vlan 10
switchport mode access
switchport voice vlan 20
switchport port-security
switchport port-security maximum 2
switchport port-security mac-address sticky
switchport port-security mac-address sticky aaaa.bbbb.cccc
no ip address
duplex full
speed 100
priority-queue out
no mdix auto
switch#sh mac-address-table int fa 1/0/10
Mac Address Table
Vlan Mac Address Type Ports
10 aaaa.bbbb.cccc STATIC Fa1/0/10
20 dddd.eeee.ffff STATIC Fa1/0/10
Total Mac Addresses for this criterion: 2
switch#
Solved! Go to Solution.
08-08-2007 05:40 AM
Hi Ken,
When a voice VLAN is configured on a secure port that is also configured as a sticky
secure port, all addresses seen on the voice VLAN are learned as dynamic secure addresses,
and all addresses seen on the access VLAN (to which the port belongs) are learned as
sticky secure addresses.?
So the IP Phone?s MAC address would not be learned as sticky address.
Port Security Configuration Guidelines:
http://www.cisco.com/en/US/products/hw/switches/ps646/products_configuration
_guide_chapter09186a00802cb7c4.html#wp1038546
Hope that helps !
~JG
Please rate helpful posts.
08-08-2007 05:40 AM
Hi Ken,
Hope that helps !
~JG
08-08-2007 07:34 AM
Hi there JG.
That is fantastic. many thx for your help. Thought I was going mad :))
Kindest regards,
Ken
