How to come back 7.2(2) to 7.1(1)
Aug 8th, 2007
Last day i update 7.2(2) from 7.1(1). Some problem is create (mail is not comming) but outgoing mail is ok.
I want to come back previous version.
What is procedure to back previous version. I can't backup previous version.
Downgrade is command but i can't understand.
Pls help me
Overall Rating: 5 (1 ratings)
rochopra Wed, 08/08/2007 - 03:44
Downgrade command only works with moving from Pix v7.x to 6.x
To downgrade from Version 7.2(x) to 7.1.(x), you must perform the following steps:
Step 1 Load the earlier Version 7.1(x) image
copy tftp flash
Filename: pix712.bin
Step 2 Reload the device so that it will be use the Version 7.1(x) image.
Step 3 Copy the ASDM Version 5.1(x) image copy tftp flash
Filename: XXX.bin
Step 4 Enter the following command, this will tell the security appliance where to find the image:
boot system flash:/pix712.bin
asdm image flash:/ asdm file
wr mem
Reload the PIX again and you should be running on 7.1(2)
Do make sure to take backup of configuration before performing above steps.
Hope this helps.
