schemberg Wed, 08/08/2007 - 01:33
Hi Remy,
you are right, but routeplan report - as far as I know - is not available via AXL...
Axel
this is the url passed to the CCM to find unassigned DN
routeplanreportlist.asp?patternType=-1&findBy=name&match=begins&pattern=&rows=20&utilityList=
So patternType=-1 is one of the sql column you have to search
You can make SQL query with AXL and search patterntype=-1
Keep me inform if you find stg
Rate this post
Remy
msabir Wed, 08/08/2007 - 06:15
You can use the status field of the device. If it is not Registered, then it is inactive device. It basically tells you about devices/phones as opposed to lines/number.
