configuration tool
Aug 8th, 2007
Dear Sir,
I find some product cannot be located inside configuration tool.
If a product cannot be located in configuration tool, does it mean it is End Of Sale already?
Thanks.
Jagdeep Gambhir Wed, 08/08/2007 - 04:48
  • Red, 2250 points or more
Yes, most likely that product is EOS.
~JG
josephschung Wed, 08/08/2007 - 06:21
If a component of a switch does not see under the switch in the configuration tool. Does it mean it is not supported by the switch?
Thanks.
Jagdeep Gambhir Wed, 08/08/2007 - 06:27
Yes, it could be not supported or EOL. Which device you are looking for ?
~JG
Please rate helpful posts
josephschung Wed, 08/08/2007 - 06:49
I have two case.
In the first below, I cannot find item 4.
1.CISCO2811-SEC/K9, 2811 Security Bundle, Advanced Security
2.NM-16A, 16-Port Asynchronous Module
3.CAB-OCTAL-ASYNC, 8-Lead Octel Cable (68-Pin to RJ45)
4.MBS-D-C2811SEC, MBSS SDS for CISCO2811-SEC/K9
5.CON-SUSA-C2811SEC, Console Cable for 2811-SECK9
In the second case below, I cannot find item 3 and 4.
1. CISCO3825-HSEC/K9, 3825 Security Bundle, 64MB Flash/256DRAM
2. PWR-3825-AC, Cisco 3825 Power Supply
3. S382AISK9-12311T, Cisco IOS Advanced IP Services
4. AIM-VPN/EPII-PLUS, DES/3DES/AES VPN Encryption/Compression
Many thanks.
Pavel Bykov Wed, 08/08/2007 - 08:00
  • Silver, 250 points or more
Could it be that the code have changed, or the product has been replaced by a newer one with different code?
