Would you like to enter the initial configuration dialog?
Aug 8th, 2007
I am configuring an 187 router, but after a reboot I always get this message:
I've tried a wr mem and copy running-config to startup-config but every time I get that message after a restart.
Pavel Bykov Wed, 08/08/2007 - 01:48
  • Silver, 250 points or more
What is your configuration register settings?
You can find this out using "show ver" command.
spremkumar Wed, 08/08/2007 - 02:46
  • Red, 2250 points or more
hi
change the same to 0x2102 and save the config.
once u r done reset and check for the same .
(use config-register 0x2102 command to do the same)
regds
whiteford Wed, 08/08/2007 - 03:01
Thanks that worked, what did I do? What does that all mean?
Richard Burts Wed, 08/08/2007 - 05:39
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Andy
The difference between 0x2142 and 0x2102 is one bit in the 16 bit config register. This particular bit instructs the router to ignore the content of the startup config in NVRAM at bootup.
Setting the config register to 0x2142 is the essential step in doing password recovery. When doing password recovery people should reset the config register back to 0x2102 but frequently people forget to do this. And the result is what you have experienced that every time the router boots it loses its config and you have to build the config over again. The startup config is really ok and in NVRAM but the router is ignoring the startup config. When you set the config register to 0x2102 it should work fine.
Rick
