graemeporter Wed, 08/08/2007 - 03:13
  • Bronze, 100 points or more
Hi there,
You could try:
show ip cache flow
See if that does what you need.
Kind regards,
Graeme
Pavel Bykov Wed, 08/08/2007 - 03:39
  • Silver, 250 points or more
Also you could try enable accounting on the interface. It will not always display active connections since it's incremental (old connection stay in the list) but it can display what is flowing.
commands are:
(config-if)#ip accounting
#show ip accounting
#clear ip accounting (reset list)
