CME 4.1 Phones display random characters
Aug 8th, 2007
CME 4.1
Cisco 2851
c2800nm-ipvoicek9-mz.124-15.T1.bin
7961 and 7911
firmware: sccp.8-2-2SR1
30 channel PRI E1
When a call is received and connected from a mobile or landline, the display shows a random collection of characters below which is the calling number in brackets.
I have tried a number of different CLID suppression commands and isdn commands which have not worked.
When I downgraded to CME 4.0(2) c2800nm-ipvoicek9-mz.124-11.T2.bin, the display showed just the calling number, which is preferable.
bwalchez Tue, 08/14/2007 - 06:42
upgrade the ios to latest one IOS 12.4(15)T1 and check it if ti solves the issue
ccpagel Thu, 08/16/2007 - 07:27
I also have the same issue with the garbage characters on the display when an incomming PSTN call is connected. Did you manage to find a fix?
I changed phones firmware with no luck. I did however remove my voice translation rule which was adding a '90' to the calling party number on the PRI. Once this was removed the issue cleared, but meant we lost the 90.
Chris
williams-daniel Thu, 08/16/2007 - 07:35
Yes, but my solution involved taking out the trunkgroup commands from the incoming dial-peer.
below is what I mean if you have not used it before.
controller E1 0/0/0
pri-group timeslots 1-31
trunk-group 1 timeslots 1-31 preference 1
dial-peer voice 1 pots
trunkgroup 1
incoming called-number .
So I just took out the trunkgroup 1 command and replaced it with port 0/0/0:15.
I am also translating the incoming called number and then applying to the voice-port 0/0/0:15:
voice translation-rule 1
rule 1 /^.*/ /9\0/ type national national
rule 2 /^.*/ /900\0/ type international international.
Dan
