DHCP problem number 2
Aug 8th, 2007
I am trying to configure a DHCP server on a Cisco router so it assigns the same ip each time to a specific PC. I use the following commands:
rea#config t
Enter configuration commands, one per line. End with CNTL/Z.
rea(config)#ip dhcp pool net10.9.9.x/24
rea(dhcp-config)#host 10.9.9.151 /24 ?
<cr>
% This command may not be used with network, origin or vrf pools.
Why i can not do that .
moses
moses12315 Wed, 08/08/2007 - 03:03
ok but when i use the command host address [mask | /prefix-length], i receive the following message:
I can not proceed .
moses
dimuthurathna Wed, 08/08/2007 - 03:08
When a DHCP client that has previously had a DHCP-assigned address is started again, the client goes into an INIT-REBOOT state. The client will attempt to verify that it can still use the same address by sending a DHCPRequest packet, populating the DHCP Option Field "DHCP Requested Address" with the previously assigned IP address.
