08-08-2007 03:05 AM - edited 03-05-2019 05:46 PM
Dear Sir,
Does ASA5510 supports the following?
1. Active-Active HA
2. BGP
Solved! Go to Solution.
08-08-2007 07:10 AM
08-08-2007 03:38 AM
Hi Joseph
1) Yes active/active has been supported from version 7.x onwards for the ASA
2) No, as far as i an aware ASA supports static routing/RIP/OSPF and with version 8.0 EIGRP but not BGP.
Jon
08-08-2007 06:17 AM
Hi Jon,
Is there any documentation for the A/A support? And which bundle product should I go for?
Thank you.
08-08-2007 06:31 AM
Joseph
Attached is a link to failover for ver 7.1 on the ASA which covers active/active failover.
http://www.cisco.com/en/US/docs/security/asa/asa71/configuration/guide/failover.html
As for which bundle, that really depends on your requirements. What do you need apart from firewalling ?
Jon
08-08-2007 06:40 AM
Thanks for the link Jon. Is it for ASA5510? I cannot find such description.
As far as I know, ASA5510 need a upgrade license to have HA. But I cannot find any product of 5510 that provide Active/Active HA.
Besides, I need the following features:
1. SNMP
2. OSPF
3. BGP
4. TACACS+
5. SYN Flood attack
6. DOS attack
Thanks.
08-08-2007 06:44 AM
Joseph
You need to make sure you purchase the ASA5510 with a security Plus license. Then you can do your active/active failover.
The link i sent is for all ASA models.
Apart from BGP which we have already covered the standard ASA should meet your requirements.
Jon
08-08-2007 07:04 AM
Hi Jon,
I choose the following products, what do you think?
1.ASA5510-SEC-BUN-K9, ASA 5510 Security Plus Appliance with SW, HA, 5FE, 3DES/AES
2.SF-ASA-7.2-K8, ASA 5500 Series Software v7.2
08-08-2007 07:10 AM
Hi Joseph
This looks like the right product.
Jon
