Edison Ortiz Wed, 08/08/2007 - 05:54
  • Hall of Fame,
    Founding Member
I don't recommend designating a Cisco router or switch as NTP server. I recommend using a NTP server in the internet and point these devices to it.
These 51 devices have IP connectivity to the internet ?
If so, just enter
ntp server [ip address]
in config mode and they will sync with the NTP server. You want may to configure the timezone and offset values as need
clock timezone
is the command you need.
For a list of public NTP servers, please visit ntp.org
HTH,
Pavel Bykov Wed, 08/08/2007 - 06:15
  • Silver, 250 points or more
Don't forget to configure timezone, sou all your devices switch to summer-time and back automatically without problems. Depending on your NTP server, it could be UTC, so you should set up offset.
Commands are:
clock timezone NAME OFFSET_FROM_UTC (1 for central European for example)
clock summer-time NAME recurring last Sun Mar 2:00 last Sun Oct 3:00 (times when to switch to summer time and back)
NTP server setup is easy:
"ntp server x.x.x.x" command is the most important command, and it tells device where to get the time from. Has to be reachable by IP. Could be a server in your network, that synchronizes to internet NTP. Or it could be a PC with NTP server functionality (see manuals for your operating systems). Or it can be another Cisco device.
You can secure your NTP a bit by using authentication. Update calendar, define update intervals and so on. Everything optional.
Like this:
ntp authentication-key 1 some_password
ntp authenticate
ntp trusted-key 1
ntp clock-period 17179927
ntp update-calendar
ntp server x.x.x.x key 1
ntp server y.y.y.y key 1
You can have as many servers as you want, but don't overdo it.
upendra07 Fri, 08/10/2007 - 09:14
Dear
Can i use windows xp for ntp server
How can i do
Richard Burts Fri, 08/10/2007 - 09:37
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
If you install some application/service you could use a Windows XP machine as the NTP server. But the Windows Time service is not NTP and will not serve as an NTP server.
In the previous post was this comment:
actually NTP is always UTC. So it is helpful to configure the clock timezone offset so the clock will look like local time.
Rick
dphills18 Mon, 03/17/2008 - 21:37
can you recommend a good ntp server application.
Richard Burts Mon, 03/17/2008 - 22:26
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Dwayne
I have not used it but I have heard some good things about the NTP implementation by Meinberg for Windows. Additional information is probably available from this link:
http://www.meinberg.de/english/sw/ntp.htm
Rick
dphills18 Tue, 03/18/2008 - 10:10
I got everything working. Thanks for all your input. I used the app that was suggested. Eventually, I will go to NTP Appliance. Better security.
I had to do a couple additional things to make it work though:
1.)HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\W32Time\TimeProvid
ers\NtpServer
I changed Enabled from 0 to 1.
2.)HKLM\SYSTEM\CurrentControlSet\Services\W32Time\Config
LocalClockDispersion Entry
Change from default of 10 to 1
hobbe Tue, 03/18/2008 - 09:15
  • Gold, 750 points or more
I have been using a Meinberg hardware device for my NTP needs and I like it alot.
It uses the GPS signal to get the time and if something happens to the GPS signal it has a internal clock that will hold time within specified parameters for atleast 10 days.
This solution is alot better than using any server desktop or network machine as a NTP server since the device has a better crystal than any "normal" server and it is constructed to do what it does and it does it good.
Good luck
