08-08-2007 04:40 AM
I'm having trouble moving my SLB configuration to the CSM. Please take a look at my very basic code below...why isn't this working?
module ContentSwitchingModule 4
vlan 101 server
ip address 10.101.1.20 255.255.255.0
vlan 102 client
ip address 10.102.1.10 255.255.255.0
gateway 10.102.1.1
serverfarm ACS
nat server
no nat client
real 10.101.1.30 8080
inservice
vserver TEST
virtual 10.101.1.40 tcp www
serverfarm ACS
persistent rebalance
inservice
Thank you,
Scott
Solved! Go to Solution.
08-08-2007 06:49 AM
the problem is the server traffic not returning to the client through the CSM.
[see the server pkts counter being null].
Make sure the CSM is the default gateway for the server or configure a client natpool in the serverfarm to force the csm to nat the client ip.
Gilles.
08-08-2007 05:15 AM
this config is ok.
It should work.
What is not working exactly ?
Can you ping the csm vlan ip addresses ?
Can you ping the vserver ?
Do you see any hit on the vserver with the command 'sho mod csm 4 vser name test detail' ?
Gilles.
08-08-2007 05:59 AM
I thought the config was correct as well...Yes, I can ping both the CSM VLAN as well as the vserver. It almost appears that everything is working, but I'm not getting the content...the connection is timing out.
I ran a sniffer from my box, and I see my machine sending a SYN to the vserver, but I never receive a SYN/ACK...I eventually receive a FIN/ACK.
show mod csm 4 vser name test detail
TEST, type = SLB, state = OPERATIONAL, v_index = 30
virtual = 10.101.1.40/32:80 bidir, TCP, service = NONE, advertise = FALSE
idle = 3600, replicate csrp = none, vlan = ALL, pending = 30, layer 4
max parse len = 2000, persist rebalance = FALSE
ssl sticky offset = 0, length = 32
conns = 1, total conns = 3
Default policy:
server farm = ACS, backup =
sticky: timer = 0, subnet = 0.0.0.0, group id = 0
Policy Tot matches Client pkts Server pkts
(default) 3 7 0
08-08-2007 06:49 AM
Gilles.
08-08-2007 07:05 AM
I created a natpool...and the natting seems to be working, but my server pkts are still at 0.
show mod csm 4 conns detail
prot vlan source destination state
In TCP 101 10.128.117.106:3455 10.101.1.40:80 ESTAB
Out TCP 101 10.101.1.30:8080 10.90.66.155:8205 ESTAB
vs = TEST, ftp = No, csrp = False
real = (n/a)
The 10.90.66.155 is my nat address.
show mod csm 4 vservers detail
virtual = 10.90.70.40/32:80 bidir, TCP, service = NONE, advertise = FALSE
conns = 0, total conns = 9
Default policy:
(default) 9 24 0
08-08-2007 07:45 AM
use a natpool with an address in the range 10.101.1.x to make sure the server gets directly to the csm.
If you use another address, the server will use its default gateway again which is not the csm apparently.
Gilles.
08-08-2007 09:33 AM
That seems to be working...thank you very much! I'm just a little confused as to why changing to natpool to the same network as the servers fixed the issue. Do you know why it didn't work using a different network configured on the same switch?
Thank you very much for all your help Gilles!
Scott
08-09-2007 12:15 PM
because when the natpool address is in the same subnet as the server, the server will arp directly for the address instead of using its default gateway.
The all problem here is the routing table of the server which is not correct to forward the traffic back to the csm.
Gilles.
