Iomem memory message
Answered Question
Aug 8th, 2007
Hi!
I bought a refurbished router (3640- 64MB/16MB flash) for my home lab in ebay. During booting process I got this message regarding memory as follows:
"If any of the above Memory Requirements are UNKNOWN, you may be using an unsupported configuration or there is a software problem and system operation may be compromised. Rounded IOMEM up to: 4MB. Using 6 persent iomem. [4MB/64MB]."
Is there any problem with the memory? I want to make it sure before to call the vendor.
Thank you for your reply.
Best regards
Correct Answer by Richard Burts about 9 years 7 months ago
Sanny
I do not see anything in what you posted that indicates that there is any problem. The first part of the message
"If any of the above Memory Requirements are UNKNOWN..." is a standard message that always prints out during the boot process for this platform. And then it indicates that it will be using 4 MB out of 64 MB for IO memory. This is quite normal during the boot process.
Rick
Overall Rating: 5 (1 ratings)
Correct Answer
Richard Burts Wed, 08/08/2007 - 05:16
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Sanny
Rick
Richard Burts Thu, 08/09/2007 - 10:13
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Sanny
Thank you for using the rating system to indicate that your question was resolved (and thanks for the rating). It makes the forum more useful when people can read a question and can know that they will read a response which resolved the question. I encourage you to continue your participation in the forum.
Rick
