Enabling Multiple Ports to access Video Conferencing Equipment.
rwamstutz
All, I need to enable multiple ports (some in a range) so outside Video Conferencing Equipment can access by VC.
How do I allow the ports below using my access-list command? Is there a range command?
access-list acl_out permit tcp any host 64.171.51.211 eq
1720 TCP
3230-3235 TCP
3230-3253 UDP
Jon Marshall
Are you using a pix/asa device ? If so you can use object-groups ie.
object-group service VCE_tcp tcp
port-object eq 1720
port-object range 3230 3253
object-group service VCE_udp udp
access-list acl_out permit tcp any host 64.171.51.211 object-group VCE_tcp
access-list acl_out permit udp any host 64.171.51.211 object-group VCE_udp
Jon
