Unity VM integration with 3rd party Phone Systems
Aug 8th, 2007
Is it safe to say that both Nortel (CallPilot ) & Avaya IP as well as traditional voicemail solutions would not support any other companies IPT deployment .
Also would it be true and acceptable to say that the Cisco IP VM solution will integrate with any other manufactures IPT solution ?
Brandon Buffin Wed, 08/08/2007 - 09:28
  • Purple, 4500 points or more
You can integrate 3rd party voicemail solutions with Cisco Callmanager using SMDI. See the following link.
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_upgrade_guides_chapter09186a0080623595.html#wp1097725
Cisco Unity voicemail will integrate with many other telephony solutions. See the following link.
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_installation_and_configuration_guides_list.html
Hope this helps. If so, please rate the post.
Brandon
