Console Configuration Parameters
Aug 8th, 2007
When setting up a console connection to a Cisco router from a PC, using some form of terminal emulation software, are there certain settings that must be configured, such as baud rate (eg. 9600), 8 bit, no parity, and so on ?
Overall Rating: 4 (3 ratings)
graemeporter Wed, 08/08/2007 - 06:40
  • Bronze, 100 points or more
Hi there,
Typically, HyperTerminal and TeraTerm Pro will have compatible settings by default.
I use TeraTerm with the following :
Baud rate: 9600
Data: 8 bit
Parity: none
Stop: 1 bit
Flow Control: none
I've had no problems with this configuration; I've even performed device recovery via X-Modem transfer over that serial connection, without issue.
Hope this helps!
Kind regards,
Graeme
Pavel Bykov Wed, 08/08/2007 - 06:49
  • Silver, 250 points or more
Settings on both sides must match. Default parameters are as Graeme listed.
If you prefer different parameters, you can set baud rate using configuration register:
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a008022493f.shtml
Other parameters you can set under "line console 0" configuration mode. "stopbits" configure stopbits, and "parity" configures parity.
Speed increase might save you time, if you are loading software using XMODEM/YMODEM.
But otherwise default parameters should be enough.
jwdoherty Wed, 08/08/2007 - 06:57
Yup, and I believe you gotten most of the defaults. (You didn't note flow control; believe off usually works.) Do note, however, the console can also be reconfigured. Which can be a problem if they have been changed from the normal defaults.
BTW, setting a higher baud rate, if supported, can be very helpful if you need to load an IOS image via the console.
