Routing VLAN
Answered Question
Is there a problem with running an IP address on the main interface with sub-interfaces for Vlans or should the IP addresses all be sub-interfaces?
EXAMPLE:
interface GigabitEthernet0/0
ip address 172.16.1.2 255.255.0.0
bridge-group 1
media-type rj45
interface GigabitEthernet0/0.1
encapsulation dot1Q 11
ip address 192.168.11.254 255.255.255.0
no cdp enable
interface GigabitEthernet0/0.3
encapsulation dot1Q 33
ip address 192.168.33.254 255.255.255.0
no cdp enable
or
no ip address
media-type rj45
bridge-group 1
interface GigabitEthernet0/0.2
no cdp enable
no cdp enable
What would the repercusions be?
Both seem to work the same.
Correct Answer by Pavel Bykov about 9 years 9 months ago
The big difference is that packets traveling from "interface GigabitEthernet0/0 " are not send encapsulated. They don't have 802.1Q tags, and therefore do not belong to any VLAN. They will be received by either NATIVE VLAN on other side (if it's a switch with trunk port), or interface that has no encapsulation on another side (if it's a router).
In second configuration you are throwing two IP networks in one VLAN (172.16.1.2 255.255.0.0 and 192.168.11.254 255.255.255.0 )
Not that it won't work, but it's not recommended and is not a good design practice. You are creating VLANs to separate broadcast domains, and create separate networks, but here you have two networks in one VLAN - VLAN 11
Where does bridge-group 1 lead to?
Overall Rating: 4.5 (2 ratings)
Jagdeep Gambhir Wed, 08/08/2007 - 07:19
  • Red, 2250 points or more
Both configs are ok , it will work fine.
~JG
Correct Answer
Pavel Bykov Wed, 08/08/2007 - 07:52
  • Silver, 250 points or more
