arp traffic
Answered Question
Aug 8th, 2007
Is there anyway to prevent so much arp traffic? I am seeing that we are having a ton of it and would like to set something up so the computers dont have to broadcast all the time.
Correct Answer by Jon Marshall about 9 years 11 months ago
Hi Matthew
Yes, you can statically map all the mac-addresses on your switches/routers/clients/servers if you really want to remove the broadcasts.
But this is not really practical. Arp is a normal part of the TCP/IP and the broadcasts should not propogate beyond the local vlan.
What you could do is increase the arp timers on all your devices so an arp entry remains in the arp cache for longer.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Wed, 08/08/2007 - 07:38
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Matthew
Jon
MZydorczyk2 Wed, 08/08/2007 - 07:41
I didnt think it would be practical but thanks for that suggestion, i will try it. Thanks.
Jon Marshall Wed, 08/08/2007 - 07:45
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Matthew
You can do this but beware that if you increase the arp cache that means you have to wait longer for it to time ou eg.
you have a user PC that is broken. You change the PC and give it the same IP address. For it to work you will have to wait until the arp caches time out the entry.
Generally speaking arp cache timers have been decided by vendors after years of experience with ethernet so please be careful when changing.
Jon
wochanda Wed, 08/08/2007 - 15:12
  • Silver, 250 points or more
interface vlan 100
arp timeout 300
