ACL question
Answered Question
Aug 8th, 2007
I have an acl to get all users out to the internet-
access-list Internet_access_out tcp_group_internet_access
access-list Internet_access_out extended permit tcp any any object-group internet_test
access-list Internet_access_out extended permit tcp any any eq www
access-list Internet_access_out extended permit tcp any any eq domain
access-list Internet_access_out extended permit tcp any any eq https
access-list Internet_access_out extended permit tcp any any eq ftp
access-list Internet_access_out extended permit tcp any any eq citrix-ica
access-list Internet_access_out extended permit tcp any any range 2095 2095
access-list Internet_access_out extended permit tcp any any range 9100 9100
When I change the source (any) to the ip address of the proxy server, I get an error message.
4 Aug 08 2007 09:25:29 106023 10.132.129.30 65.54.152.126 Deny tcp src inside:10.132.129.30/50285 dst outside:65.54.152.126/80 by access-group "Internet_access_out" [0x0, 0x0]
I would appreciate any help. Thanks.
Correct Answer by acomiskey about 9 years 8 months ago
Or apply the acl in interface inside instead.
Correct Answer by Jon Marshall about 9 years 8 months ago
Mike
What happens if you use the Natted address in your access-list ie x.x.x.207 instead of the 10.132.29.30 address ?
Jon
Overall Rating: 5 (2 ratings)
acomiskey Wed, 08/08/2007 - 07:43
  • Green, 3000 points or more
So you made it like this...
access-list Internet_access_out extended permit tcp host 10.132.129.30 any eq www
and you receive the Deny message above?
acomiskey Wed, 08/08/2007 - 07:54
Well that doesn't make sense does it? Sure that you put "host 10.132.129.30 any" and not "any host 10.132.129.30"? How is the acl applied?
mike.feeney Wed, 08/08/2007 - 08:06
I just changed it to this-
Here is the error message-
4 Aug 08 2007 12:08:26 106023 10.132.129.30 199.181.132.250 Deny tcp src inside:10.132.129.30/52112 dst outside:199.181.132.250/80 by access-group "Internet_access_out" [0x0, 0x0]
mike.feeney Wed, 08/08/2007 - 08:16
A little more info-
TFBPCiscoASA(config)# sh run access-g
access-group dbadirect_tunnel1_acl in interface outside
access-group Internet_access_out out interface outside
TFBPCiscoASA(config)# sh run static
static (inside,outside) x.x.x.207 10.132.129.30 netmask 255.255.255.255
The static for the proxy is not the outside interface address.
Correct Answer
Jon Marshall Wed, 08/08/2007 - 08:18
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Mike
Jon
Correct Answer
acomiskey Wed, 08/08/2007 - 08:24
mike.feeney Wed, 08/08/2007 - 08:28
Thank you both for your help. Changing the acl to use the natted address worked.
