MARS License: Print is too small!
Answered Question
Aug 8th, 2007
  • Silver, 250 points or more
Does anyone else find the size of the type used on the Mars license too small? I'm referring to the license tag on the front panel of the MARS box.
I'm using a magnifying glass on it and can't tell the difference between S and 5, G and 6, O and 0, Z and 2.
The box is basically a boat anchor until I go through every permutation.
Please tell me if I am missing something here?
Thanks in advance and all posts will be rated.
Correct Answer by mhellman about 9 years 8 months ago
They used to print this information on the back cover of the quick start guide that came in the box.
Overall Rating: 5 (1 ratings)
Correct Answer
mhellman Wed, 08/08/2007 - 08:09
  • Blue, 1500 points or more
pmccubbin Wed, 08/08/2007 - 08:30
Thanks. They print it on the back of the CD.
Unfortunately, the print is the same size and is of even poorer clarity than the one on the MARS box.
I'll have to take a picture and send it to TAC just to get a license.
It's ironic that the MARS 100 I was working on yesterday had the license pre-loaded. This MARS 50 must have been sitting around the warehouse.
mhellman Wed, 08/08/2007 - 18:28
We've had a couple MARS boxes come through the door and I actually remember thinking that the license for later ones were difficult to read.
