VTP configuration file
Aug 8th, 2007
My company deploys are large number of devices so we generate all our switch configuration files with scripts. Is it possible to have the VTP commands as part of our configs? I've been testing this and receiving the error "%The VTP Password cannot be changed until after the system configuration has been
read". I receive this when the switch is booting. Upon inspection of the configuration file and the vtp status, the vtp commands are disregarded during startup. I know if I manually cut and paste the configuration in I'm fine. TFTP is just so much more convenient for the number of devices we send out. Any suggestions?
MUHAMMAD SHAHEEN Wed, 08/08/2007 - 14:59
  • Silver, 250 points or more
When you send the copy of configuration(startup-config) file using tftp, you should also include vlan.dat file for the same switch. vlan.dat file holds all vtp related info into a database format for server and clients. If your switches run intransparent mode then vtp info is part of the actual config.
Shaheen
