Sup-4 on Catalyst 4500 vs. Sup-32 PISA on Catalyst 6500
Aug 8th, 2007
Which Supervisor Module would have faster performance on Layer-3 routing? Supervisor-4 on a Catalyst 4506 or a Supervisor-32 PISA on a Catalyst 6506? I would like to know as I am planning an upgrade next year. This is for a medium-sized collapsed core/distribution-layer.
Thanks.
Overall Rating: 5 (1 ratings)
Edison Ortiz Tue, 08/14/2007 - 14:34
  • Hall of Fame,
    Founding Member
The PFC3B card makes Sup32 PISA the clear winner.
There are a tons of stuff you can run in hardware with PISA that you would have to run in sofware with the SupIV.
See both Supervisor data sheets and you be the judge.
SupIV
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_data_sheet0900aecd8035cf2b.html
Sup32-PISA
http://www.cisco.com/en/US/products/hw/switches/ps708/products_data_sheet0900aecd805a6b87.html
Jon Marshall Tue, 08/14/2007 - 17:06
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
I completely agree with Edison on this. As a further point if you are using this to do all your inter-vlan routing etc, the 6500 switch is a better investment in the long term. It is Cisco's premier switch and if you find you need more throughput you could upgrade your supervisor from a Sup32 to a Sup720.
Jon
hermanaccd Fri, 08/17/2007 - 10:34
Thank you everyone for your suggestions and feedback. I really appreciate it!
