08-08-2007 09:30 AM - edited 03-14-2019 10:59 PM
I'm recieving an error on the voice translation ruleset and inbound calls are no longer translating. deb voice translation shows the following:
"Translation ruleset with tag-10 doesn't exist"
I can see the call hitting the appropriate dial-peer. The relevant configuration is thus:
voice translation-profile 8611
translate called 10
translation-rule 10
Rule 1 8611 4300
dial-peer voice 8000 voip
translation-profile outgoing 8611
preference 2
destination-pattern 8611
progress_ind setup enable 3
voice-class codec 1
session target ipv4:10.10.10.10
dtmf-relay h245-alphanumeric
no vad
Full Details of the debug:
.Aug 8 12:07:39 cdt: regxrule_profile_translate: number=5551212 type=national plan=isdn numbertype=calling
.Aug 8 12:07:39 cdt: regxrule_get_RegXrule: Invalid translation ruleset tag=0
.Aug 8 12:07:39 cdt: regxrule_profile_match: Error: ruleset for calling number not found
.Aug 8 12:07:39 cdt: regxrule_profile_translate: No match: number=5551212 type=national plan=isdn
.Aug 8 12:07:39 cdt: regxrule_profile_translate: number=8611 type=unknown plan=unknown numbertype=called
.Aug 8 12:07:39 cdt: regxrule_get_RegXrule: Translation ruleset with tag=10 doesn't exist
.Aug 8 12:07:39 cdt: regxrule_profile_match: Error: ruleset for called number not found
.Aug 8 12:07:39 cdt: regxrule_profile_translate: No match: number=8611 type=unknown plan=unknown
.Aug 8 12:07:39 cdt: regxrule_profile_translate: number= type=UNKNOWN plan=UNKNOWN numbertype=redirect-called
.Aug 8 12:07:39 cdt: regxrule_profile_match: Error: ruleset for redirect-called number not found
.Aug 8 12:07:39 cdt: regxrule_profile_translate: No match: number= type=UNKNOWN plan=UNKNOWN
.Aug 8 12:07:39 cdt: regxrule_dp_translate: calling_number=5551212 calling_octet=0x21
called_number=8611 called_octet=0x80
redirect_number= redirect_type=4294967295 redirect_plan=4294967295
Solved! Go to Solution.
08-08-2007 03:17 PM
try to configure:
voice translation-rule 10
rule 1 /8611/ /4300/
And should work.
08-08-2007 03:17 PM
try to configure:
And should work.
08-13-2007 09:10 AM
Switching to voice translation-rule resolved this issue. Thanks!
Any idea why the translation-rules would suddenly no longer work (perhaps IOS was upgraded unbeknownst...)?
08-13-2007 09:36 AM
No idea about the old translation commands, never used them.
Thanks for the nice rating and good luck!
