08-08-2007 03:13 PM - edited 03-18-2019 07:41 PM
I understand CDR information from Communications Manager is usually sent to a syslog server and can be processed with third party applications or through SNMP using MIBs. Does the same situation applies for CCME? Where can I find an url explaining the procedures or a third party application which sucesfully recover and process this data ?
08-08-2007 03:42 PM
Hola,
The preferred way with CCME is radius accounting.
This is the main reference document:
for a third party application, developed by a cisco partner, look at stonevoice.com
Hope this helps, please rate post if ti does!
08-09-2007 08:38 AM
Or you could specify a logging server and enable accounting.
logging x.x.x.x
gw-accounting syslog
