501 VPN....
Aug 8th, 2007
I have a pix 501 and I just need the config to setup a VPN. I will be using the VPN client software to access it. I searched around and couldn't find the config that I needed.
Thanks!
johnroche_2 Mon, 08/13/2007 - 05:42
You could use the VPN wizard.
It takes about 5-10 minutes to set it up
