Switch 500 series - Smart ports
Aug 8th, 2007
Hi all,
I am configuring a cisco switch 500 series and all access ports will be set as cisco-desktop smart port.
This switch will be connected to a 3com switch via uplink, vlan1. Which smart port should I use? Can I also use cisco-desktop?
Jagdeep Gambhir Fri, 08/10/2007 - 06:04
Hi Muca,
Desktop should work fine since we have all access ports.
Please rate helpful posts
muca Sat, 08/11/2007 - 13:45
Someone else told me:
You'll want to use the switch role on this port. Cisco-desktop role enables portfast and BPDUguard. If the 3com switch talks spanning-tree, this port will shut down upon connecting to the Cisco.
