Inbound/outbound calling with FXO lines
olighec
I have a 2821 running CME 4.0, connected to PSTN with 4 FXO lines on a VIC2-4FXO.
I have inbound DID calling working with "connection plar opx (extension)", but I am unsure of how to set up outbound calling. I want each phone to use its own FXO port both for inbound and and outbound calling.
Is that possible?
Chris
mark_gardner
Yes ...
You have taken care of the inbound calls with the connection plar opx (extension) command.
Outbound calls as follows :
\\ Create some translation rules and profiles to change the 9 to the relevant dial-peer number
voice translation-rule 1
rule 1 /^9/ /19/
voice translation-rule 2
rule 1 /^9/ /29/
voice translation-rule 3
rule 1 /^9/ /39/
voice translation-profile OUT_PORT1
translate called 1
voice translation-profile OUT_PORT2
translate called 2
voice translation-profile OUT_PORT3
translate called 3
\\ Create dial peers pointing out individual ports
dial-peer voice 1 pots
destination-pattern 19T
port 0/0/0
dial-peer voice 2 pots
destination-pattern 29T
port 0/0/1
dial-peer voice 3 pots
destination-pattern 39T
port 0/0/2
\\ apply the translation profiles to the individual ephone-dn's for the port you want to go out of
ephone-dn 1 dual-line
number 5001
call-forward busy 1000
call-forward noan 1000 timeout 10
translation-profile incoming OUT_PORT1
ephone-dn 2 dual-line
number 5002
translation-profile incoming OUT_PORT2
ephone-dn 3 dual-line
number 5003
translation-profile incoming OUT_PORT3
For example :
Extension 5001 dials a 9 for an outside line, translation-profile incoming OUT_PORT1 is applied and changes the number to 19, which matches dial-peer voice 1 pots, and the call goes out port 0/0/0.
5 Replies 5
mark_gardner
Yes ...
rule 1 /^9/ /19/
rule 1 /^9/ /29/
rule 1 /^9/ /39/
translate called 1
translate called 2
translate called 3
port 0/0/0
port 0/0/1
port 0/0/2
number 5001
number 5002
number 5003
For example :
Thanks! That's exactly what I needed. I had done that earlier, but I didn't do the translations correctly, so not only calls that started with '9' went to the dial-peers, causing internal extensions to not be able to call each other. This is a much better solution.
paolo bevilacqua
Not sure if it is in 4.0, If you can upgrade to 4.1 that is 12.4(11)XJ4, the you have a command 'trunk' to do this, under ephone-DN that simpliefies much the configuration for outgoing calls..
I will look and see if that exists in 4.0.
Thanks!
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124newft/124limit/124x/124xc4/cme401tk.htm#wp1049435
It seems the trunk command is available in v4, it does simplify the configuration as paolo stated.
All good in the end :)
