ASA as a Remote VPN Server
Aug 8th, 2007
do you guys know of a good link that can walk me thru on how to setup an ASA5510 as a Remote VPN Server?
I will have users connect to the office from the road using the cisco vpn client. I need split tunnel as well because I only need to encrypt their traffic to the corp office, nothing else; they can still use their local gateway to go out to the internet.
I've seen a few links but nothing; most of them point me to the GUI stuff (ASDM). I need the CLI stuff
can anyone please help? or if anyone can just write the commands that would also be great
thank you
Patrick Swackhammer Thu, 08/09/2007 - 06:04
I just found this link with a quick search:
PIX/ASA 7.x: Allow Split Tunneling for VPN Clients on the ASA Configuration Example
Links for more examples:
Do you plan on using SSL VPN or Cisco IPSEC VPN Client? SSL VPN client can auto-deploy to any non-Vista Windows machine (does not yet support Vista to my knowledge). If remote users have Vista, you'll need to use VPN Client software installed on their machines. Also consider how you will do you require two-factor, or pointing ASA to a Cisco Secure ACS server, or perhaps pointing to Windows Active Directory for authentication? Lots of possibilities...
