set connection tcp-mss using policy-map in ASA 7.x
Aug 8th, 2007
Is it possible to set "connection tcpmss <value>" by using policy-map and not the global command "sysopt connection tcpmss 1400". Reason is that the sysopt feature is extremely usefull when using tunelling [vpn]. For other communication though you get to restrict the mss value, while you could use a higher value [i.e. 1460 for ethernet].
Regards.
Overall Rating: 1 (1 ratings)
