Pix two outside ????
Aug 8th, 2007
I have Pix 515 firewall. I have two ISP line. I know pix have just one outside. but if I want configure two outside connected with two ISP line then it is possible ???. that means if one ISP line fail then other line is ok for connectivity .
Biplob
akabirbdcisco Sat, 08/11/2007 - 03:04
Hi biplob. How are you. I am kabir from Bangladesh .
yes i possible
Your IOS must be 7.2(2).
you configure trck and sla command
Pls check attachement file.
johnroche_2 Mon, 08/13/2007 - 05:11
if you are not running version 7 on your pix be very carefull that you have enough memory in the PIX to support version 7 ios
