ACS error codes explanation
Aug 9th, 2007
Is there a document with ACS error codes (occuring in log) explanations? I've found only the document with ACS error codes list.
Best regards,
Krzysztof
darpotter Thu, 08/09/2007 - 09:07
you should be able to type
csutil -e at the cmdline to get a description of the error - this is for the numberic ACS codes anyway.
Don't know if they still keep this up-to-date as it was one of the long list of things I used to do!
