Pavel Bykov Thu, 08/09/2007 - 04:20
  • Silver, 250 points or more
You will need physical access to the switch.
realiswitch Thu, 09/27/2007 - 01:29
thanks, it's ok
i followed the steps and i reset the password...
THANKS A LOT!!
Now....may you tell me how can i reset cfg of my 2950?
MUHAMMAD SHAHEEN Thu, 09/27/2007 - 03:28
You should follow the document link sent by mohammedmahmoud it will take you through all the required steps to restore previous configuration and change the passwords.
But If you want to erase the current config and re-start everything from scratch, then in type in the following command
Switch#erase nvram:
and that reload the switch
Shaheen
glen.grant Thu, 09/27/2007 - 03:56
  • Purple, 4500 points or more
Just use "write erase " then reload the box .
