CRA- Error while handling the input request
Aug 9th, 2007
I have received this error message when try to add new resources, or skill in CRA Admin page
"Error while handling the input request"
This is the first time install CRA, connect with LDAP in setup page is successfull.
Any one know about this problem
dsweeny Tue, 08/14/2007 - 13:45
Workaround:
Instructions for running the ClearArchive.exe:
1. Copy ClearArchive.exe to one of the nodes in the cluster (e.g. the target node). You can put it under c:\ or any location really.
2. Double click the exe.
3. Depending on your network speed (since it needs to check with LDAP), it takes about 10 sec. to run the tool.
4. After that, the user will either get a confirmation message box (for success case); or an error message box (i.e. if the cluster is not in synch).
