Router out of mem since Image update - constantly rebooting
whiteford
I have a cisco 837 router, I have updated the routers IOS and it seems the image could be too big, as it boots up it's says it's out of memory then reboots and so on and so on. I want to put a smaller image (IOS) back on to it, but if it keeps rebooting I can't, any ideas around this?
19 Replies 19
Pavel Bykov
Level 5
Level 5
You need to connect to the router using console cable and break the boot sequence. You will enrer rommon. Ther you will need to delete the new image and load the old image.
spremkumar
Level 9
Level 9
Login via the console port and make sure you are getting onto the rommon prompt with ctrl+brk sequence keys.
After you get onto the box do refer any of recovery procedures mentioned in this link.
http://www.cisco.com/en/US/products/hw/routers/ps380/products_tech_note09186a008009429e.shtml
regds
I'm trying:
rommon 1 > set IP_ADDRESS=ip_address
rommon 1 > set IP_SUBNET_MASK=ip_subnet_mask
rommon 1 > set DEFAULT_GATEWAY=default_gateway
rommon 1 > set TFTP_SERVER=TFTP_server
rommon 1 > set TFTP_FILE=TFTP_file
rommon 1 > save
but set is not found?
it says :
rommon 1 > set
BSI=0
RET_2_RUTC=0
RET_2_RTS=15:56 UTC Aug 1 2007
CRASHINFO=flash:crashinfo_20020301-000042
?=1
I can't get to that, only rommin:
I'm trying:
rommon 1 > save
it says :
rommon 1 > set
BSI=0
RET_2_RUTC=0
?=1
Tried that it keeps rebooting, my image erazed the boot (only) image on the router.
Try "dnld" command to load the image using xmodem. You can use hyperterminal (or other terminal emulation software you are using) and send the software using console cable.
I have putty and HT, on my laptop I have a tftp server running with a good image. Can you explain how I will do this please?
hi
try with HT ...
did u try dnld command as mentioned out by Pavlo ?
regds
I'm trying to, but what are the commands etc to do this?
I have the imagine on my laptop and on a tftp server on my laptop. My laptop has a console cable connect to the router.
hi
can you issue "?" and paste the available commands out there in ur current prompt wherever you are stuck up at present ?
regds
!rommon 18 > ?
alias set and display aliases command
boot boot up an external process
break set/show/clear the breakpoint
confreg configuration register utility
cont continue executing a downloaded image
context display the context of a loaded image
cookie display contents of cookie PROM in hex
dev list the device table
dir list files in file system
dis display instruction stream
dnld serial download a program module
frame print out a selected stack frame
help monitor builtin command help
history monitor command history
meminfo main memory information
repeat repeat a monitor command
reset system reset
set display the monitor variables
stack produce a stack trace
sync write monitor environment to NVRAM
sysret print out info from last system return
tftpdnld tftp image download
unalias unset an alias
unset unset a monitor variable
xmodem x/ymodem image download
