span ro rspan from one switchport to another switchport
Answered Question
Aug 9th, 2007
  • Silver, 250 points or more
Is it possible to monitor a switchport on one switch and send that traffic to another port on a different switch? switches are connected using trunks.
Correct Answer by wochanda about 9 years 10 months ago
Yes, RSPAN is what you need. If your switches run IOS, here is the idea:
Source:
vlan 511
remote-span
monitor session 1 source interface Fastethernet0/11
monitor session 1 destination remote vlan 511
All switches between:
vlan 511
remote-span
Destination:
monitor session 1 source remote vlan 511
monitor session 1 destination interface Fa0/31
The config is the same on most IOS switches, here is the guide for the 2970:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2970/software/release/12.2_25_se/configuration/guide/swspan.html#wp1081130
Overall Rating: 5 (1 ratings)
Correct Answer
wochanda Thu, 08/09/2007 - 05:14
Source:
vlan 511
remote-span
vlan 511
remote-span
Destination:
Tshi M Thu, 08/09/2007 - 05:30
Thanks for the quick reply...I should have been more specific and mentioned that the source port is not part of a VLAN. It is used to connect to our WAN. Does the switchport need to be part of the VLAN created for the RSPAN?
wochanda Thu, 08/09/2007 - 05:34
Nope, that doesn't matter. So long as the port on the source switch is some sort of ethernet port this will work.
If it is some sort of WAN port on the 6500, let me know and i'll give you tips on how to grab that traffic.
Tshi M Thu, 08/09/2007 - 05:45
Thanks... it is indeed a port on the 6509.
wochanda Thu, 08/09/2007 - 05:55
If it is an ethernet port, that is fine.
If it is a port on a Flexwan/OSM/SIP module, let me know.
