Upgrade to Unity 5.0(1)
Trent Hurt
I'm currently researching the upgrade process to Unity 5.0(1), and I would like some advice on a few configuration issues. I have 2 clusters with Unity 4.0(5) VMO, both with failover and they are digitally networked together. One cluster is running server 2000. The other cluster is running server 2003. I also have off box exchange. The upgrade path I'm thinking of doing is to do a rolling upgrade on the cluster that has 2003 on it, and then on the cluster that is 2000. Take a dirt backup, reload with 2003 install Unity 4.0(5) back on it and then do a dirt restore. Once the dirt is complete then do the rolling upgrade to Unity 5 on this cluster. I have a question though about this, can you have a Unity 4.0(5) and a Unity 5 cluster digitally networked together? Any help or advice is greatly appreciated.
Christopher McAlpin
Community Manager
Community Manager
Unity 5.0 and Unity 4.0(5) are compatible for Digital Networking.
Christopher McAlpin
Community Manager
Community Manager
