MPLS routed protocols
Aug 9th, 2007
Hi, I need some information about which protocols can NOT be router in a MPLS network, or in other word which are the protocol that can be router and te solituin (Tunnel, etc) for the protocol can not be done.
Brgds
swaroop.potdar Thu, 08/09/2007 - 07:27
  • Blue, 1500 points or more
Hi, you can run any routing protocol from static to OSPF for MPLS label switching (except BGP).
For TE you can use only 2 of the above that is OSPF and ISIS.
HTH-Cheers,
Swaroop
gsantini Thu, 08/09/2007 - 07:32
No, this is not the information that I need. Sorry. I try to said the ROUTED protocols (netbios, kerberos, etc), no routing protocol.
swaroop.potdar Thu, 08/09/2007 - 10:34
Thanks for clarifying the question. At present you can run MPLS inlcuding MPLS TE for IP only among the routed protocols.
HTH-Cheers,
Swaroop
