fast switching on different interfaces
Answered Question
Aug 9th, 2007
How can I find out if an interface supports fast switching? I am using IOS 12.2. So it should be enabled by default.
Correct Answer by wochanda about 9 years 5 months ago
You can issue a 'show interface stat'. This will show you per-interface which packets were switched via 'Processor' (slow path), or 'Route-cache' (CEF path).
In 12.2 IOS, most everything should get CEF switched.
Overall Rating: 5 (1 ratings)
Correct Answer
wochanda Thu, 08/09/2007 - 10:08
sarah12345 Fri, 08/10/2007 - 06:21
Hi William,
It seems almost everything is going through the slow path, even on the GigE interfaces. Strange.
Thanks a lot!
Sarah
