Dual client authentication problem in AP1200
Aug 9th, 2007
I have got an AP1200 with EAP-TLS authentication. I would need to associate a new non EAP authentication device. It supports WEP or MAC authentication. I read that I can only use MAC with EAP-TLS, but I have tried to configure it by adding:
username aaaabbbbcccc password 0 aaaabbbbcccc
username aaaabbbbcccc autocommand exit
aaa authentication login 701 local
dot11 association mac-list 701
dot11 ssid myssid
authentication open mac-address 701 alternate eap eap_methods
authentication key-management wpa
guest-mode
access-list 701 permit aaaa.bbbb.cccc 0000.0000.0000
access-list 701 deny 0000.0000.0000 ffff.ffff.ffff
.....but It does not work. I get the following error:
dot11_auth_send_msg: client FAILED to authenticate aaaa.bbbb.cccc, node_type 64 for application 0x1
dot11_auth_delete_client_entry: aaaa.bbbb.cccc is deleted for application 0x1
%DOT11-7-AUTH_FAILED: Station aaaa.bbbb.cccc Authentication failed
Could you help me, please?
Thanks a lot for your help
Juan Manuel
didyap Thu, 08/16/2007 - 06:33
  • Silver, 250 points or more
Try a standard access list and have configuration . Just have this configuration access-list 701 permit aaaa.bbbb.cccc
jmcandelera Fri, 08/17/2007 - 04:59
I have tried again the same configuration but this time I configured one ACL entry instead of two (I deleted : access-list 701 deny 0000.0000.0000 ffff.ffff.ffff). Unfortunately I does not work yet.
AP1200 has got the following IOS:
c1200-k9w7-mx.123-4.JA
Perhaps it could be a version problem, could not it?
I have included a debug file.
Thanks for your help
Juan Manuel
Trending Topics - Security & Network
