Using vibrate uri
Aug 9th, 2007
Hi everybody,
I've just realized that vibration feature is added as an xml URIs. Based on 7920 Release Notes for Firmware 3.01:
With firmware release 3.01, the Cisco Unified Wireless IP Phone 7920 can now receive a URI message from a third party XML application that activates the vibrate device on the phone. You can use these parameters to customize the vibration sequence:
Vibrate Duration?Sets the vibrate-on interval in milliseconds
Silence Duration?Sets the vibrate-off interval in milliseconds
Count?Sets the number of times to repeat the vibrate on/off sequence
Syntax for the vibrate URI is:
Vibrate:[{vibrateDuration}:{silenceDuration}:{count}]
I am testing a 7920 with cmterm_7920.4.0-03-01 firmware which is newer that 3.01.
In user profile, I have set ?VibratingCallAlert? to ?on? and ?Warning Style? to ?Vibration? and when I call phone, it vibrates.
When I pushed Vibrate URI with this
<ExecuteItem Priority="0" URL="Vibrate:[1000:1000:5]"/>
I do not get error which shows that phone understands the xml. However it does not vibrate.
Anybody has tried this feature?
I appreciate all your feedbacks,
Parisa
msabir Thu, 08/09/2007 - 12:18
  • Bronze, 100 points or more
I would love to try vibrate feature. Anyone got it working?
stahkaoja Fri, 08/10/2007 - 03:08
I haven't had any success with 7920's, but 7921G's work nice (firmware 1.03)
Cheers,
Sami
parisatashakori Mon, 08/13/2007 - 10:00
I also got same result. works for 7921 only.
There most be some setting issues on phone. I hope somebody would have experienced and share with us.
Parisa
msabir Tue, 09/04/2007 - 10:54
I got it working on 7920 and 7921, here is the correct syntax:
