Console access Cisco 1113 ACS
Aug 9th, 2007
We have a new ACS and cannot access the device thru the console. I am using TeraTerm and I can see the characters but it is a bunch of garble almost like the terminal settings are incorrect. I have 8 1 and no parity for the Serial port settings. Has anyone run into this? If so, how did you get it solved? Thanks.
mark.blanchfield Thu, 08/09/2007 - 09:55
I got it to the login screen now but do not know what the Admin password is?? Is there a default login initially for this device? I found documentation on how to change it but you need to be in the device first. Thanks
dave.chadwick Thu, 09/13/2007 - 02:35
If its the Appliance that your using then you need to set your serial emulation to 115000 8 none 1.
