marcuscastellanos Thu, 08/09/2007 - 09:25
J,
The main difference is:
A higher-resolution, graphical 4-bit grayscale display (320 x 222)
Support for double-byte characters and Unicode text to benefit Extensible Markup Language (XML) application developers
Support for both IEEE standard 802.3af inline power and Cisco inline power
You can view the info here
http://www.cisco.com/en/US/products/hw/phones/ps379/
Rob Huffman Thu, 08/09/2007 - 09:47
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Jack,
Just to add a note to the good info your received from Marcus. The main difference between the 7940G/7960G and the 7941G/7961G are the "backlit" line keys and upgraded displays that are on the newer 7941G/7961G and not on the 7940G/7960G. We have many of all 4 models deployed in our environment and our users much** prefer the 41G/61G models. Have a look;
The Cisco Unified IP Phone 7961G provides six programmable backlit line/feature buttons (these line keys now change color depending on the status of the call ie: Ringing,Hold,Idle **Very nice feature**) and four interactive soft keys that guide a user through call features and functions, and audio controls for high-quality duplex speakerphone, handset, and headset. A built-in headset port and an integrated Ethernet switch are standard with the Cisco Unified IP Phone 7941G. The phone also features a ***best-of-class large, higher-resolution grayscale pixel-based LCD ***. The display provides features such as date and time, calling party name, calling party number, and digits dialed. The graphic capability of the display allows for the inclusion of higher value, more visibly rich Extensible Markup Language (XML) applications and double-byte languages.
From this doc;
http://www.cisco.com/en/US/products/hw/phones/ps379/products_data_sheet0900aecd802ff020.html
The Cisco Unified IP Phone 7960G provides six programmable line and feature keys (**not backlit**), plus a high-quality speakerphone. It also has four dynamic soft keys that guide users through call features and functions. A built-in headset port and an integrated Ethernet switch are standard with the Cisco Unified IP Phone 7940G. The phone also includes audio controls for the full-duplex speakerphone, handset, and headset. This phone also features a large, pixel-based LCD display that provides information such as date and time, calling party name, calling party number, and digits dialed.
From this doc;
http://www.cisco.com/en/US/products/hw/phones/ps379/products_data_sheet09186a0080091984.html
Hope this helps!
Rob
j.magee Thu, 08/09/2007 - 10:24
Thanks Guys....Just what I was looking for!!
Chris Deren Fri, 08/10/2007 - 05:09
  • Hall of Fame,
    2017 IP Telephony, Contact Center, Unified Communications
The huge difference, which you cannot see is the additinal memory in the new generation phones which will allow you to run new CM features bundled in CM 6.X. Even though Cisco is still selling 7940/60, look for them to become absolete in the adaptation of CM 6.X. They basically have no more memeory to handle anything more, i.e. recording, intercom, etc.
Chris
yussetamayo Tue, 09/14/2010 - 09:53
Helloa guys
Anyone of you, can help me? I need to know wich is the cisco 7940/60 resolution, I have been looking for this info for a long time.
There is no data sheet tell me about that?
regards
jacklee1976 Mon, 12/30/2013 - 19:09
The other difference is 7960 is much slower than 7961 in restarting from CME router.
R1(config-telephony)#restart all
reset 2 phones 5 seconds, this could take several minutes per phone Starting with 7960 phones
