error when run ip accounting 6509 hybrid Cat IOS
mframadan
i want to run ip accounting in cisco switch 6509 hybrid Cat IOS
gateway0(config-if)#ip accounting
Accounting will exclude mls traffic when mls is enabled.
Jagdeep Gambhir
Level 10
Level 10
Hi ,
It is normal behavior . The reason is that 'normal' data traffic in the 6500 MSFC is NOT actually switch by the MSFC, but rather is switched in hardware by the PFC (policy feature card).
The IP accounting feature will only count traffic that passes through the MSFC. This means it will count traffic that is punted to the MSFC for process. For example this is traffic with IP options set, or traffic that is unable to be switched in hardware.
~JG
