Deny Telnet and Permit SSH on 3560
Answered Question
Aug 9th, 2007
I am trying to secure vty access to my 3560's. I enabled ssh, and added the following to my vty 0 4 line:
line vty 0 4
privilege level 15
password XXXXXXXXXXXX
length 0
transport preferred ssh
transport input ssh
I thought this would block telnet traffic, but I still can access it via telnet.
I am running 12.2(25)SEE4
Anybody know what else is needed?
Thanks.
Correct Answer by Jon Marshall about 9 years 9 months ago
I'm not sure you do need access-list as well. The 3560 supports vty 0 - 15. Is there a chance that when you telnet you are using a vty above 4 to get in ?
Jon
Overall Rating: 5 (1 ratings)
Jagdeep Gambhir Thu, 08/09/2007 - 09:52
  • Red, 2250 points or more
You need ACL's
3560(config)# access-list 101 deny tcp any any eq telnet
3560(config)# access-list 101 permit ip any any
3560(config)# line vty 0 15
3560(config-line)# access-class 101 in
Please rate if helps
~JG
Correct Answer
Jon Marshall Thu, 08/09/2007 - 09:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jon
david-flores Thu, 08/09/2007 - 10:05
You were correct. It was not ACL, I must have been coming in on 5 15
when I put the command no exec under line vty 5 15 that made the difference. Thank you very much.
