Aug 9th, 2007
Hello all I will starting the CCNA course on Aug 20, I would apprecaite if anyone can give some book sto buy in order to prepare for the course as well as the exam, I have secured some lab time, my other question how long should my lab times be per day taking into consideration I work full time., I do have knowledge in certain aspects of netwoking including basic protocols and the OSI layers and subnetting.
NateBattle Thu, 08/09/2007 - 10:44
I find the books from Cisco Press to be more on point than others. Also, As far as lab time, spend as much time as it takes for the commands to be second nature.
purohit_810 Fri, 08/10/2007 - 04:56
Hey if you are just staring than go for SYBEX CCNA book.
It will give lot easier language than cisco press book.
To take exam CCNA go on search your paper no you will get testking ans actual test latest braindumps from there.
You will see same question into exam beleive in me.
You will give me thanks after exam on " [email protected] "
Enjoy the life at smarter way.....
Dharmesh Purohit
