Easy (Hopefully) VPN client config question
Aug 9th, 2007
This seems like it should be easy to do, but here I am. I want users to connect to our VPN via the Cisco Client 5.0.01.0600 and AFTER the connection launch a script. The end result being they receive their mapped drives. I know about the Netlogin force setting, but i would rather find another option if possible...especially to support Vista clients. Thanks.
Marty
srue Fri, 08/10/2007 - 01:14
you can either configure the vpn client to launch prior to login (if the vpn client pc is part of your domain), or write a login script/ bat file and just have them click on it manually once they connect. It will have to be tailored per user/passwd, but it's pretty easy to set up.
