Remote VPN on ASA Internet issue
Aug 9th, 2007
I have configured Remote Access om my ASA 5510 but the issue is clients are unable to browse the internet infact I have also enabled the split tunneling. Running Config is attached Kindly set me know the solution
oszkari Sun, 08/12/2007 - 06:02
Try this config,
I have modified the split tunnel and nat 0 acl. For a better control i changed the vpn pool to a separate subnet. In your config it was overlaped with your inside lan.
Oszkar
imranraheel Mon, 08/13/2007 - 03:26
Thanks oszkari but dont you think if the VPN pool IP is different than vpn clients will not be able to communicate with the Internal users and there systems
acomiskey Mon, 08/13/2007 - 04:48
  • Green, 3000 points or more
Imran,
That is not the case. The vpn pool should absolutely be different than the inside subnet.
imranraheel Mon, 08/13/2007 - 05:07
Oh ok well still the VPN clients will able to access the internal LAN and ppl
oszkari Mon, 08/13/2007 - 05:06
It will work even if you use the same subnet for the vpn pool as the inside lan. But it is not a recommended practice.
regards,
Oszkar
