VPN Forms I get an IP but no traffic passes.... please help
Aug 9th, 2007
Result of the command: "show run"
: Saved
ASA Version 8.0(2)
hostname asa
domain-name
enable password names
name 192.168.1.33 VPN
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
pppoe client vpdn group BELLSOUTH
ip address pppoe setroute
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd encrypted
boot system disk0:/asa802-k8.bin
ftp mode passive
dns server-group DefaultDNS
domain-name access-list Split_tunnel_list standard permit 192.168.1.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool INTERNAL VPN-192.168.1.37 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-602.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable 8080
http 0.0.0.0 0.0.0.0 inside
http 0.0.0.0 0.0.0.0 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
no crypto isakmp nat-traversal
no vpn-addr-assign aaa
no vpn-addr-assign dhcp
telnet timeout 5
ssh timeout 5
console timeout 0
vpdn group BELLSOUTH request dialout pppoe
vpdn group BELLSOUTH localname vpdn group BELLSOUTH ppp authentication pap
vpdn username password *********
dhcpd auto_config outside
dhcpd address 192.168.1.2-VPN inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
webvpn
enable outside
csd image disk0:/securedesktop-asa-3.2.0.136-k9.pkg
svc image disk0:/sslclient-win-1.1.0.154.pkg 1
svc enable
group-policy GroupPolicy1 internal
group-policy GroupPolicy1 attributes
vpn-tunnel-protocol IPSec l2tp-ipsec svc webvpn
split-tunnel-policy tunnelspecified
split-tunnel-network-list value Split_tunnel_list
webvpn
url-list none
svc keep-installer installed
svc rekey time 30
svc rekey method ssl
svc ask enable
username Monkey password ********** encrypted
username Monkey attributes
vpn-group-policy GroupPolicy1
tunnel-group DefaultWEBVPNGroup general-attributes
address-pool INTERNAL
tunnel-group RAS type remote-access
tunnel-group RAS general-attributes
default-group-policy GroupPolicy1
prompt hostname context
Cryptochecksum:xxx
: end
what am I missing? I think its a no nat rule but I don't know how to correct this problem..
Thanks in advance
steve_steele Fri, 08/10/2007 - 14:25
I think that the mtu on the outside interface may be part of the problem, try setting it to 1492.
I've only done this on a pix with 6.2 or something running on it and its a while ago.
nat (inside) 0 access-list no-nat
access-list no-nat permit ip
